how it happened!!major error but plc running!
PSpal
Jan 2011
surat
52
The PLC 5/80E is running/processing data & communicating..I mean one "part" of operation is working fine but when I make online connection I found "major error" of "overflow". to make the thing worse , the programme using 2 mcp's and 1 is blocked..!! is it possible?>:whistle:
Is it possible?
Yes, through mis-understanding and lack of knowledge, almost anything appears to be possible.
Many PLC5 programs have routines that attempt to automatically reset faults so that the program can keep running. The condition that caued the fault is still there and needs to be found and fixed.
u may be right.. but in this case..I feel..it is written with knowledge....
a) in plc 5/80 etc,it is possible to make more than one MCP--and it is used..generally it is not..
b) the error caused "one block"to stop-whereas the second"block" kept running...i good judgement
I just want to confirm--even in case of "major error" 1 part of cummunication is possible
the mcp block/hold as per logic ..but how to restart that without reset/power recycle..that part is not written in programme
Post your .rsp file and we can take a look.
FYI an "overflow " will not fault or stop a PLC5. Unlike a SLC500 it will.
Has anyone on the Forum used the Red Lion "Graphite Core Controller", part number GRAC0005 ? My understanding of the Core controller was that it...
1,812
We had several power failures today, the power was off and on a couple times by the time we got around to all the equipment and got the mains...
23
4,661
Good morning guys and gals. I have a micrologix 1100 with a proface hmi. The program was working well yesterday. THis morning i came in, made a...
1,538
hi all, i just have to ask if this has happened to you. we are having issues with some hydraulic pumps not holding up and we are replacing...
19
6,307
There used to be a huge spreadsheet on the Rockwell website listing modules and compatible firmware versions for different versions of RSLogix...
8,795
