How to amplify the 12V encoder pulses into 24vdc
AB2005
Nov 2006
Lahore
319
Hi;
We have 5ppr 12vdc encoders (06nos) available in stock which I want to use at a machine to upgrade it. But Fatek PLC, which I want to use here, accepts only 24vdc signal.
Is there any cheaper way to amplify 12vdc encoder pulses into 24vdc?
Is there a device that will amplify a 1-2.2v signal to a 24v signal. I dont want to build a circuit.
3,584
Most PLCs are 24v for digital logic, will a Digital input card detect a 12v (automotive) signal as a 1 Looking to do some work on a...
4,309
Hello every one!!! (1) I got problem in connection of encoder 12 v and delta plc EX ... How can i connect encoder with delta plc beacuse delta plc...
1,395
Hi Does anyone know if availabe, a DC voltage controller with the following requirements: Output voltage 0 to 12VDC Current Max 100A Analog Input...
1,708
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,148
