DC voltage controller 12V 100A
tarik1978
Mar 2010
casablanca
716
Hi
Does anyone know if availabe, a DC voltage controller with the following requirements:
Output voltage 0 to 12VDC
Current Max 100A
Analog Input (0-10v or 4-20mA) for voltage control
programmable ramp_up and ramp_down
programmable curent limit
Feedback current
this is for Brake Pads Shear Test Machine
It depends a bit on your budget and how critical the machine is, but if you need that much current with a variable DC voltage I would recommend looking into modular rackmount power supplies. You'd buy a chassis and then whatever modules you want to fill it in. The chassis and a few 0-20v or 0-30v DC paralleled modules at ~25A a piece would do the job quite nicely, and be controllable as a single unit.
Alternatively, an open frame or component type programmable power supply would work well if you want it inside of a cabinet. Either style would be available with either serial or analog control, serial being more common in my experience. I would personally stay away from benchtop power supplies and get something more robust.
Maybe check out some supplies from Chroma or Instek, see if there's anything there that piques your interest.
Hello PLCs.Net! We have 3 elements in a star configuration, and each of the elements are rated for 20kW 120V - This is all I know about the...
1,277
We have an ArmorStart Distributed Motor Controller (284G-FVD7P6D-25-RRG-CBG-DB1-EMI). It is used to run an Over Head Lift motor on a Hoist. One...
19
8,520
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
137
I've got 6 identical regenerative vacuum blowers powered by 6 identical drives in 3 identical panels all fed from the same 1 main building feed...
27
883
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
203
