how to automaticlly erase unused tags in a ControlLogix program
buhnen
May 2008
Somewhereland
131
Hello people,
Just a simple question, maybe sombody knows...
After doing my first project in RSLogix5000 I've noticed that I have created some tags that I didn't finally used for my program.
This time I just went over the tag list and erased them. But when I have to make a big program this erasing task can be heavier. Can RSLogix5000 erase automaticlly the unused tags in a project?
Thanks in advance.
Tags can be deleted Online, as long as they aren't IN USE.
In use can also mean being part of an HMI or other Communications message block (as in, on poll from an OPC server).
tomalbright said:
thanks, I haven't had any luck with this. A V.15 Contrologix, and in RUN. I think the "RUN" is the problem, and I am unable to change it.
If you are in "Run" and cannot change it, your key switch is the culprit. Switch the key on the processor to "Rem" and see if that makes a difference.
Set the controller to remote with the keyswitch. Make sure you only turn it to remote though. After this it will be in remote run and you will be able to edit the program online.
Hi Guys,
Here is THE ultimate Solution. You must be ONLINE and in RUN Mode to do this properly.
Go to the Edit Tags Form of the Tag Database. Mark ALL Tags (Mark 1st and then do Ctrl+A).
Then press DEL Button on your keyboard. You are prompted for every Tag which is in use somewhere. Because the correct Answer is allready marked (ok), just press Enter. Now put something with a little weight on your Enter Button and go for a smoke.....
When you come back all unused tags should be gone.
Greets
Hello. I'm working on a RSView32 .gfx that was started by a someone who moved elsewhere. There are three yellow lines on the page that I can't...
1,397
I have an old Magelix XBTGT4330 HMI with an existing program loaded and user security set for downloads. How can I wipe this thing out so I can...
4,235
Hi, I have an OMRON CP1E PLC, it already has a program inside however i want to put a new program in it. Is there anything i have to do e.g...
3,647
I have an S7-200 that is password protected. Is it possible to totally erase the memory without the password. It is off an old piece of equipment...
5,433
Is there a command that you can use against a UDT that will fill it with zeros? Of course the UDT has dint, bool and strings... EX: FLL...
11,344
