You have to investigate the switch settings in the ASB adapters and the chassis. That requires you power down the system and remove modules to be able to investigate th switch settings.
With the switch settings you can know the addressing scheme (½-slot, 1-slot, 2-slot), what rack no's are assigned, and the starting groups.
And with that you can figure out exactly what I/O addresses are assigned to the physical I/O. It will also be key to understand the BTR/BTW for analog I/O.
