How to change screen saver on PanelView Plus 400
mroyce09
Aug 2016
NH
Hi. I have a used PanelView Plus 400 that already has a custom screen saver on it and I'm looking to change the screen saver I was reading the Changing the Screen Saver Bitmap document and have a few questions:
"Create a file on a desktop or laptop computer named autorun.bat. In the file place the following three lines (place the name of the custom bitmap in the place of “oem.bmp”):
pause"
1) Is the autorun.bat file created using notepad?
2) How do I determine what the name of the custom screen saver is? I'm assuming it is not ssfloat.bmp.
3) Is "Storage Card2" the name of the compact flash card?
Thanks!
1) Is the autorun.bat file created using notepad ?
Yes
In the example shown 'oem.bmp' is the name of the screensaver file. It can be any name. It is copied from the compact flash into the Panelview as 'ssfloat.bmp'.
Yes
Be sure to note the dimensions of your screen in pixels and create the .bmp file as the same dimensions.
Hello everyone, I am currently trying to build a HMI(KTP400 basic) for myself. I have some UDT data and use these UDT data for 20~...
1,264
Hello everyone, I'm trying to figure out some weird behavior with some numeric displays. The problem is that I center numeric displays over...
894
Question on CCW v12. Using a Micro800 and PV800. Want to make screen changes from PLC. Using the HMI system tag "$SysCurrentScreenSecure", I can...
1,371
Wizards, I have an operator display that was built in Java script, running on RPI, that was a pain to update. I've taken the advice I found here...
3,027
Hi All Just wondering if anyone can help me out here. I have an acid dosing pump that doses within the pH range of 0-14. I need to dose to 1...
1,223
