Advanced HMI Screen Change
Gadelric
Nov 2018
Midwest
137
Wizards,
I have an operator display that was built in Java script, running on RPI, that was a pain to update.
I've taken the advice I found here and moved to Advanced HMI to build these displays.
So far I have been able to get things to work out, but I want to do more than what I have stumbled through.
1.) In about a year, I will start running a new product down my line. During the change over I will like to have a second screen built that will display the "new part". I cant seem to figure out how to force a screen change via the PLC. Any advice would be great, just remember that I'm no expert on VB so explain like I'm 3 years old.
2.) I have hard coded everything in the displays, I would be interested in making the displays more dynamic. Example, my next build cycle might not change the overall profile of my part, I just might put fasteners in a different location, so I would just need to move the indicator's position on the display and not have to build an entirely new display. I have read that INI files can be used for this type of thing, but most of the information that I was able to gather about INI files was either way to advanced for my simple brain or was for a process that I did not understand. This is the least of my concern atm, the screen change is considerably more important because there is a 90% chance my entire part will change.
I have built 4 stations already, still have 7 more to do, so I have lots of room to learn and improve my process.
PLC is CompactLogix
PC is windows 10 mini pc
Thanks in advanced
Gad
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,681
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,066
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
944
Having a hard time getting the data received when using BeginReadMultiple. Not the most familiar with the ClxDriver and EthernetIPforCLXCom()...
2,332
I am in search of a non-PC based, non-SCADA based HMI and software that allows the ability to dynamically draw graphical objects on the screen to...
5,047
