How to change the IP address on a Micrologix 1400 using Rslogix 500
samvivi7
Apr 2016
NJ
50
Hey everyone,
i have a very very stupid stupid question.
How do i change the IP address on Micrologix 1400 using Rslogix 500. i know how to do it suing the display but i want to do it through Rslogix 500.
Thanks for the help.
Sam.
Go to Channel configuration, Channel 1, uncheck the BootP/DHCP tickbox, edit the IP and subnet mask fields (gateway too if necessary), then apply the changes.
If you do this while online, you may have to stop the CPU and then you may get kicked offline after the changes are applied if your PC is no longer on the same network as the new settings in the PLC.
If you do this offline, you will need to download to the PLC to have it take effect.
After you get it changed, POWER CYCLE THE PLC. It may appear to work fine without power cycling, but trust me, you may run into weird communication issues if you don't perform that last step.
Man you're a lifesaver!!
Thank you so much! really appreciate it.
Hi friends, Please share if you know whether I can change the modbus address of the PLC programatically (maybe by writing to S15). Appreciate...
1,002
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,878
It might seem like a stupid question but please let me elaborate. I had a PLC that already had some IP address on it which I needed to change. My...
5,809
Hi everyone, how can I change IP to a beckhoff BK9105? I tried via web broser but nothing! For the moment I have set the IP via bootp / dhcp...
2,094
Morning All, So I have a PLC-5/30 with a 1785-ENET module that I am needing to change the IP address on. I know very little about PLC's but have...
1,866
