How to Choose power supply for nema17motor
yujianou43
Nov 2019
Houston
I have the following motor:
https://www.oyostepper.com/goods-64-Nema-17-Stepper-Motor-Bipolar-09-deg-46Ncm-651ozin-2A-28V-42x42x48mm-4-Wires.html
https://www.oyostepper.com/goods-32-Nema-Size-17-Stepper-Motor-Bipolar-18-deg-18Ncm-255ozin-07A-29V-42x42x25mm-4-Wires.html
And the following driver:
https://www.oyostepper.com/goods-118-Stepper-Motor-Driver-24-72A-Max-80VAC-or-110VDC.html
I've red a lot about stepper, not sure I understood everything, but it seems that I can power this motor using any voltage I want and the actual voltage limit comes from the driver.
The driver works with 8 - 45 volts.
What I don't understand is what is the minimum and the optimal power supply needed ?
Is a 12v 1A power supply from an old router will power it (without any load) ?
Should I buy 24v power supply ? if so, how much current should it support ? I guess there is no need for more than 2.2A as the driver can't cope with higher current.
And If that is the case, to get the maximum torque should I look for a 45V power supply ?
I'd really appreciate if someone could clarify this things
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
372
hi all, i'm building a contrologix system that has 4 IB32, 2 OB32, 2 IF16HI, 2 OF16HI and 2 EN2T modules. without knowing the process or the...
3,370
Good Morning all, I am a beginner level PLC guy, I am planning to setup a lab using Allenbradly Compactlogix 5380 controller. I have selected the...
1,561
I am developing a PLC. The IDE for my PLC will be VS Code. I want my PLC to support IEC-61131-3 but only one language with is ST. Actually I...
28
7,988
Hi Gents, I need a controller for operating two ~5 HP VFDs in industrial facility. I think PLC would be an overkill for this application, since...
1,455
