How to connect a router to the PLC
What is the purpose of the router? When I see the word "router" I picture an ethernet device that also has the ability to assign IP addresses (with DHCP) and has some security features as well. It's not very common to have these in industrial networks as pretty much everything has fixed IP addresses (ethernet switches are more commonly used).
What exactly are you trying to accomplish?
You don't need a router to put a PLC on the company LAN and connect to it remotely. But, an Flexy/Cosy or Ei3 makes it a hell of a lot easier since you don't have to deal with IT in setting up a VPN. Just ask for an IP on the company LAN you can use and the Flexy/Cosy/Ei3 creates the VPN itself.
If you just want a switch to plug remote a PLC, HMI, remote I/O, etc. into, but aren't worried about accessing it remotely, Phoenix and Hirschmann make nice little switches.
http://www.alliedelec.com/phoenix-contact-2891152/70207931/ - Phoenix ENET switch
The Flexy/Cosy is made by e--w--o--n, minus the dashes. Not sure why it censors that manufacturer's name
VPN router
We use the IXON IXrouter. Really a plug and play solution to access your machine remotely. It gives you also instant access to the PLC's VNC and webserver from the iPhone/Android app. www.ixon.co
I am trying to setup a remote connection to a compactlogix plc using a stridelinx vpn router. I currently have a cmore hmi working thru the vpn...
2,053
Hi guys! My company wants to start offering remote PLC support to our customers. Currently, we use software called LogMeIn, which we can...
18
9,797
Hi everybody! I have 2 Mitsubishi Q series PLCs that have built-in IP addresses of 192.168.3.xx and both of them have Ethernet modules...
869
Dear All, I'd like to ask whether it is possible to connect 2 PLCs (both have EtherNet/IP capability) through a router. Here is the case : - We...
17
4,626
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
50
