How to count pulses from encoder
vidy_9
May 2018
india
Hi Everyone!
i'm a newbie to PLC And i have a question, How do i count pulses from a encoder giving positional feedback? my plan is to use this pulses thats received to the PLC which in return will control a driver which controls the stepper motor.
Does anyone have any solutions to this/any programming examples for me to add a Counter Into PLC to count pulses received from encoder.
(I am using a absolute rotary encoder)
Thank you :site:
No one will give you an example without knowing which PLC you are using.
Generally, with a pulse encoder you either use a counter input or a dedicated input card. These will then give you a decimal value of pulses received. From the encoder, you should be able to work out the relationship between encoder pulse and distance/movement and do your math.
sorry for the missing info!
i am currently using a mitsubishi FX3U-32 module PLC
Hello everyone...I am new in PLC programming..I am doing a project named as "Automated Water Control System" using Motorola RTU ACE3600..where i...
1,851
Over the 10+ years I have been monitoring this forum I am amazed that no one has asked this question. It should be obvious that at high pulse...
33
16,266
What is the raw count of Allen Bradley Flex Analog Output Module 5094-OF8 raw count?
128
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
147
Hi, I'm programming in RSLogix 500, and I'm wondering how I would program a Jog command that does not increase the encoder count. Basically we'd...
306
