How to display Acceleration on Red Lion HMI
gbradley
Apr 2002
Corona, Ca.
1,637
Has anybody created images that dynamically change based on inputs.
I know how to do bar graphs, but I want to show the steepness of the angle increasing as the acceleration value goes up.
attachment.php
I thought of creating a bunch of images and assigning the visibility based on the acceleration value.
HMI: G304K2 Crimson 3.0
If you just want a line, Scatter Graph it. You could pretty much graph any dynamic line with it I think. Just assign array tags to the x and y values you want to plot and change the values of those tags as needed. You could even show an s-curve this way I think.
Look in the Resources Pane under 'Bar and Line Graphs". I used it to graph scale samples over time recorded very quickly by a PLC and it worked great.
If I understand what you want, you should be able to do this by selecting the object, and on the menu bar click Behavior->Add Polar movement.
A scatter graph is more useful for fast changing values.
If I understand what you want, you should be able to do this by selecting the object, and on the menu bar click Behavior->Add Polar movement...
Thanks TConnolly, I believe this will work.
I'll just have to figure out how to convert the Acceleration rate to an angle.
I did like you said and put the scaling in the object properties.
attachment.php
Works good, I hope that it conveys the message.
attachment.php
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
176
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
410
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
152
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
110
