How to edit RSVIew SE alarm log file??
briana banks
Jul 2005
242
Hi All
I have tried using excel - deleted few rows and save it as
.dbf file,rename it as .dat file.
but the alarm log viewer cant open the edited file.
what can i do?
Is there any utility that can let edit the log file?
the RSView Enterprise File Viewer can only view and save the file
It sounds like you are trying to edit a database file with excel. I can see how this would be a problem since Excel is a spread sheet application and not a database.
If any Office app could do it, it would be Access. SQL is a standard database format that should work with anything that uses databases, but we're talking about two companys that don't exactly embrace open standards...without extending them of course.
Give Access a try.
Good luck.
I have not used RSView 32 before, but have used several other SCADA software programs. I have RSView 32 version 7.5 installed and running on my...
3,563
hai to everyone welcome to the automation world. recently i am working for RSVIEW ME project. I finished my project in my laptop. running all...
7,666
Hi All I can use RSView Enterprise File Viewer to view the file and save it as csv file. but i want to edit some rows in a way that the trend...
7,255
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
140
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
258
