How to Import/export excel sheeets
Using what SCADA software?
Else look through the documentation for "Export" then follow directions. You may need to use .csv file as an interim step.
You can do it with Citect but you have to use their dbf open and save software or the field lengths will change and then the dbf will not work properly.
Do not know about the others.
Here is an old thread from 2009 about importing and exporting tags from RSLogix5000 to or from a Microsoft Excel CSV-type spreadsheet:
http://www.plctalk.net/qanda/showthread.php?t=45230
Here is a thread about moving data from RSLogix500 to Excel, then to Citect:
http://www.plctalk.net/qanda/showthread.php?t=59879
Here is an article about creating RSLogix500 Symbols and Descriptions in an Excel CSV file, then importing them to the RSLogix software using ASCII Import:
http://www.mrplc.com/kb/index.php?article=22
Im pretty sure you can do it with most SCADA packages. If you tell us what SCADA you are using you might get a more direct answer.
Hi, When I export the csv file, display it in excel or notepad and then add some new tags that I've copied from current tags but changed the...
3,235
Hi, Import and export of project text is no problem. But how does it work if additional texts are added after I send a exported copy of the text...
892
Hello, I'm digging all over the internet to find a solution for this but haven't come up with anything yet. We have 3 nearly identical machines...
975
Hi all, Is there a way to import POU's from ABB Automation Builder to Schneider EcoStruxure Machine Expert? They both run Codesys software. ABB...
1,910
Hello everybody I work for an organization that treats wastewater. We are in the process of migrating 200 pumping stations to another...
845
