How to map the logged data in WinCC flex MP277 to remote PC on ethernet??
Ultimate99
Nov 2009
UK
Hello Friends !
Using siemens wincc flex and lgging the historical data on MP277. Need to view all the data on remote PC which is on ethernet. How to access all the logged data on that remote PC?
what settings needs to be done on MP277 and PC?
Pls help..
Regards...
Hi Jesper !
I want to move all the logged files into another computer so that
data analysis can be done.
As .csv files are generated on HMI by using circular logging, i need to move all those files to the network computer.
regards..
I think there are a number of ways. This way should be most straightforward.
A prerequisite is that the panel is integrated in the local network:
http://support.automation.siemens.com/WW/view/en/13336639
Then define one or more archives that have a network path as storage location.
That means you can then copy the regular logs to the network logs by means of the system function CopyLog (surprise !).
I Am looking to get ahold of the modbus map for an air compressor. I HAve emailed the vendor as well, just wondering if any of my friends here...
134
I was looking for this because I did not have the EDS file for the camera. I also just like to know what all the bits do sometimes. If you want to...
963
Hey guys, I am using the logging function of the Productivity PLC (P-550) to log 64 tags into a CSV file. I can access these files using the...
4,407
Hi, I use a 1768-L43S CompactLogix5343S Controller to connect with Rexroth with Air Weld Gun. the problem is when I use this controller to program...
2,206
In my mind there is a clear rationale to favour the use of input map routines with compactlogix controllers. The inputs are updated...
2,062
