How to Populate Descriptors automatically through each Level of a UDT
latchpad
Nov 2018
Michigan
16
Is it possible to auto populate descriptors of bits through multiple layers of UDTs?
For example, I want the Highlighted bit in the attached pic to be descripted as
"T3 Infeed Conveyor Pos A Stopper At Extended State" but it only shows "T3 Infeed Conveyor" and "At Extended State" but not Pos A Stopper. It seemed to skip over the Second layer of the UDT Description.
is there a solution for this? or do I have to populate each description bit by bit.
It seems insane to me that you would have to do that...
I have looked for a way to document bits within words for UDTs, when new UDTs are created. I have not found a solution.
If you find a solution, please post ... since I would be interested in the solution as well
hmm, I have never noticed that before, it might be easier to prefix the descriptions with Pos A Stopper
I thought about doing that...but then I would need a separate UDT for each position, even they will be the same, just having different descriptors...defeats the purpose doesn't it? although I might have to do it
In your Options/Ladder, what are the maximum lines for descriptor set to?
You also have to have "Show Pass-Through Descriptions" and 'Append to Base Tag Descriptions" in the Options | Application | Display tab.
That option seems to be missing in later revisions.
But no difference.
Maybe something I need to talk to the product group about.
The "Show Pass-Through Descriptions" and 'Append to Base Tag Descriptions" dont show up in the studio file I am using, But i have seen them in the RS logix 5000 file I am referencing. the Maximum lines for descriptors is 20, which is the maximum it will allow.
thanks
But no difference.
Good luck with that.
I have the same 3 pages of FTView bugs since about 2000 that have never been resolved. Even though I give them to the R. developers at least once a year. I keep getting promised "Fixed in next patch/release".
Well, they actually did remove 3 bugs from my list, but that still leaves over 150.
/shrug
Is it possible to auto populate descriptors of bits through multiple layers of UDTs? For example, I want the Highlighted bit to be descripted as...
998
Hello Everyone. I am working on a project where I need to scan in 2 Barcodes to populate 2 different tags. A glue Batch and a product serial...
3,105
Here is what I have done: We have a VersaView on the line and from what I know you cant do transfer utility for IPCs. So I got the MER file...
1,133
I need to have an array tag that contains string data from a csv file. The csv file needs to be imported once per day. Is there any simple way to...
1,812
I have a UDT with 166 Members,part of which has the 40P module definition. As part of the upgrade from a PowerFlex 40P to a PowerFlex 525, this...
2,375
