How to put PF525 in Auto?
I'm not sure what you mean by auto/manual? I'm assuming you mean something else told the drive to run, and now you have to go and press the green start button on the drive. There are different start sources which can be set with P046. I would look in the manual and figure out which one most closely matches your application.
Hi,Guys: since we used all inputs of the PLC, no any input left for our new project.we have a few PF525 connected with Ethernet, can we use it for...
1,793
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
74
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
92
Hi There, I have a filler with a coriolis flowmeter that has died. the filler requires a pulsed output (manufacturer wont edit the program) is...
271
