How to remove USB device safely?
briana banks
Jul 2005
242
Hi All
How to remove USB device safely on a PC locked with Desklock?
there is no taskbar)
Using win2k
Thnx
No they can't !! however , in the case of a USB hard drive , disable caching and allow dismount without stopping first , this should be safe . I'm sure you can do the same thing with flash drives.
Even under XP , treat a USB hard drive with the respect it deserves and either disable caching , or stop it first - thats why windows gives that annoying warning .
There are people that tell you that you can plug in a PS2 mouse with the power on , I beg to differ !
The answer is above - you said that you had desktop lock installed - if you had desktop lock installed , then the only thing you could be using the stick for is for archiving to , so why not make a shortcut on desktop lock to do what you require ?
Hi, When the HMI (KTP1200 basic) powers up, the user has to enter their credentials to log in. In the screenshot, ADMIN has already logged in...
1,007
Hi I have removed at IO card from a 1734-AENTR Point IO, from a slot in the middle, and moved the remaining cards together. Now the Point IO...
674
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
1,998
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,968
Hello all, I have a project that I need to remove so I can restore a newer version on to the machine (win7). When I use the application manager...
1,164
