How to replace processor type in existing slc program
Peacemaker
Feb 2004
22
Hi there,
I am going to replace processor type from SLC 5/03 to SLC 5/04 in the exixting program offline because I am going to use SLC 5/04 instead SLC 5/03 in the control panel. But I cannot access to the processor field in processor and I/O cofiguration page of RSlogix500. I can change I/O module, though. Any help would be much appreciated.
Richard
Here is a picture
Hi to all, We had a machine down with a bad RsLogix 5000 processor. There is a red light on the processor for ok. The bad processor is a Logix...
1,780
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
77
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,266
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,596
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,514
