how to run "select distinct field1..." on wondereware
tayfun
Aug 2009
istanbul
Hello ,
I am working on wonderware intouch scada.
How can I use the distinct of select (select distinct field1 from table1 ) ?
because I don't want the same rows .
I am using the command below
SQLSelect( ConnectionId, "table1", "BL1", "", "" );
thanks everybody in advance..
Sorry, I have no idea of what WonderWare supports as far as SQL commands go, but if it can call stored procedures (or issue raw SQL commands), you should be able to do what you ask.
details
I have table1(pen,group) in deneme.mdb .
I only want to list different groups .
TABLE1
[pen] [group]
pen1 group1
pen2 group2
pen3 group1
pen4 group2
I couldn't write the distinct because I don't know where I can use it.
as you know "select distinct field1 from table1" is used this . and I have not found anything about distinct in documents of wonderware.
anyway,
Thanks you for your hot interest.
If you lookup the
SQLSetStatement()
command in the inTouch docs, There is an example on creating any kind of SQL query you could possibly want.
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
33
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
146
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
91
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
286
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
358
