How to send larger blocks on Profibus ? (Siemens S7)
myuser
Dec 2006
Novi
I have to set communication from Siemens using Profibus, via a Deutschmann Profibus-RS Unigate Gateway to a Climatisation controller device that understands the ModBus protocol.
I've been able to establish communication through the gateway and properly send and receive data to/from the climatisation controller by using SFC14 and SFC15.
The problem is that using this methode I can only send and receive at most 16Words(32bytes) (limitation of SFC14/SFC15). The GSD file for the gateway however supports up to 122 words of consistent I/O. The way it does this is that it splits the area into 7x16Word and 1x10word chunks with sequential adresses (for example 288-319 first chunk, 320-351 second chunk and so on.)
How is it possible to write/read to this set-up ? I can't find anything in the documentation and it doesn't work in Siemens using:
*SFC14/15 for each chunk separately (8 calls of each)... Return Value 8090 always
*SFC20 for each chunk separately (8 calls of each)...Return Value 8323 for the sending part 8122 for receiving part
*SFC20 for the entire area (122 words) again the same Return Value as above
I'm not too far developing this code, so there still might be obvious problems on my part, but I'd like to know at least which direction to look into....sending/receiving each chunk separately, all the area in one piece...forget this size and do the job using 32byte areas only ?
Thanks in advance for any suggestions
SFC58 possibly?
Post your SFC20 Call, maybe your syntax is incorrect?
The call to SFC 20
A M100.0
CALL "BLKMOV"
SRCBLK :=#LV.Send_Packet
RET_VAL:=#Lv.RetVal
DSTBLK :=P#Q 288.0 BYTE 244
R M100.0
Where:
M100.0 is just a trigger I set from a VAT
LV.Send_Packet is a structure of (named) 244 bytes
Lv.RetVal is an INT
288 is the address of the ProfiBus gateway in HWConfig
Unfortunately I can't test SFC58 until tomorrow at work. (Simulator doesn't even produce the error I am having).
I am trying to send data from my Guardlogix 1756-L72S to a Leibinger JET3 UP PI Printer trough a MSG instruction, I can send information if the...
4,207
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
can the slc500 5/05 send a email and text over Ethernet ?
189
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
187
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
195
