How to show parameters of AOI arguments like MCLM
attologix
Feb 2019
Grand Rapids, Michigan
I would like to show the value of UDTs and arrays I use in my AOI in the same way as an MCLM instruction displays the individual elements of the position argument:
https://i.imgur.com/9Vnbiwb.png
Position is a Real[3] array, but it gives X_Axis, Y_Axis, and Z_Axis sub-element values that are displayed in the signature. Nice, right? (It's Rockwell, so it's a little buggy and shows '??' if you point it at a jagged array, or an array within a UDT, but when it works it's nice). And there's a double-arrow-down at the bottom to expand/display additional operands, so that a gargantuan instruction with a bunch of esoteric options can just show the normal "Position" parameter as you read through a routine to debug a problem.
But when I pass a Real[3] array to my AOI (an InOut parameter, with "VIS" visibility required in the instruction definition), I just get the array name:
https://i.imgur.com/04dgX2p.png
I'd like to make it easy to write clean code against the instructions, with UDTs and arrays that encapsulate the somewhat complicated parameter sets.
Is there anything I can do in the L5X to change the display of the parameter? What about showing or hiding the parameters as 'additional operands'?
Perhaps more importantly, what would you want to see from AOI arguments? For a handful of arguments, obviously it's easier to just pass them individually by value as inputs, but at what level of complexity would you want an array or UDT?
You'll need to create a local tag, say, "Local_POS" which is also a Real[3] tag, that you'll COP your In/Out "Position" tag into somewhere in the AOI logic.
Then create 3 Output tags, "X_Axis", "Y_Axis", and "Z_Axis" that are alias to Local_POS[0], [1], and [2].
Check the [_] Vis box for each of these output tags, and it should look like what you want.
Thanks Aardwizz, that works well enough. Just using output tags (duh, should've thought of that myself) isn't quite the as pretty as the MCLM formatting with the indentation and grouping, but it's good enough.
If anyone has the secret XML invocation for writing an L5K that does that, let me know, otherwise I'll consider this one solved.
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
907
Hi, i have a set of only 12 parameters ( 5 voltages signals, 1 freq, 5 resistances, and 1 signal through RS232 ). I wanna show these...
2,528
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
521
Please help me, I have solve many week but still not solve it. I found trouble of factory talk studio when I set tag by browse address of OPC...
124
Hi All, I'd like to know how to show 100 days of Alarm in the Alarm Summary in Aveva (Intouch) SCADA. I couldn't find any option like that in...
848
