How to Simulate a 1794-IE8 W/O one ?
skyfox
Nov 2006
CA
279
PLC 5 CPU
Is it possible to simulate functionality of an Anlog I/O card to test BTR/BTW instructions without actually having one?
What I mean is, is it possible to simulate the input Raw value read by by one these cards by using a data files in Rslogix 5?
Ie.
1. Put the simulated input raw value manually in to some data file.
2. Then execute a block tranfer read to read this value and store it in an "N" file.
What I want is to be able to accurately simulate BTR/BTW instructions. Not sure how to address or even possible to put simulated Rack/Group/Module set-up parameters in to the BTR/BTW instruction. Just trying to learn BTR/BTW without actually having access to one of these cards.
Hope someone can give me a clue as to if this can be done or I am completely and fully insane.
Thanks.
No, you cannot simulate a BTW or BTR instruction without having the module actually installed. There is no "I/O emulator" built into the PLC-5.
You can simply insert the expected range of values into the target N-file, but the only way to know if those are what you're really going to get is to install one of the modules and test it.
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
135
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
557
Hello everyone, i would like to test and run os server in pcs7 v8.2 project without rear PLC.i used plcim on ES and nettoplcsim and adjust the...
1,360
Hi all, Im new to Allen Bradley software, so i was given a existing studio 5000 plc program. i already know how to use emulator and rslinx but as...
1,426
I want to run a simulation of a program uploaded from a rockwell PLC, but I can't configure the CPU on the emulate to match the actual CPU.
2,296
