how to sinmulate a profibus master with PC
Aug 2008
france
19
Hi everybody,
I'm seeking for a software solution to simulate a ProfiBus master. I'd like to test the communication between my PLC (siemens S7300) and a future one (via a DP coupler). I've found some product on the internet but these ones are very expensive. Does somebody got a cheap solution for me???
Simply purchase the DP Coupler and the new CPU well in advance, then hook it up for a real test. Does not cost extra, is not simulated - but real. What more can you ask for ?
Another option is using WinLC but believe it takes a bit of configuring.
Probably better going with Jespers idea as you could probably get a coupler for the same price as WinLC + License...and its real.
LH
.. or connect both sides of the coupler to the profibus network of the cpu and then perform your communications tests on the same cpu !
Actually, what is there to test? A DP Coupler is probably the easiest interface there is. If I need to simulate one, I would just write a function that "pretended" to be the other CPU and test it that way.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
199
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
97
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
116
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
329
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
328
