How to teach an inclinometer?
unsaint32
Oct 2012
minneapolis
365
sorry about the fuzzy picture. I am studying about this inclinometer pinout. The gray wire is for "teach." So, applying 5V signal to the teach wire does what? I thought doing that teaches it the 0 degree point? I gave 5V to the gray wire but no change in the voltage output (at any rotational position). What am I missing here?
The teach is the Grey but you need to find your zero (Or where you want zero) touch the Grey to Ground Blue for 1 sec then find your end position then touch the grey to blue for 3 sec. your done. To go back to default touch the grey to ground for aprox 6 seconds resets. I hooked the grey and blue to a button found it was easier. I then found the correct button that is made for it. Hopefully no damage was done by applying the 5vdc ..do a reset and start over apply grey to blue for 6 sec..
http://pdb.turck.de/media/_en/Anlagen/Datei_EDB/edb_1534006_gbr_en.pdf
Hello Folks, I teach a motors course at a local community college. We have the AC/three phase/VFD technology down but we're hearing a lot of our...
2,383
Good Evening , We have a Fanuc LR Mate . Our operators have the habit of grabbing hold of the robot to clear a crash , or find the witness...
4,068
Hi, folks, how are you? Is there some way to lock/freeze Fanuc robot teach pendent? Since some of our operators jumped program lines with teach...
1,720
Hi, i have a fanuc robot with a R-30ia mate Open air controller, and a broken teach pendent (TP). is it possible to disconnect the TP and make a...
2,571
The title pretty much says it all. I have very little experience with VFD's, but it's something I want to learn more about (primarily because I...
2,657
