How to test a 1747-SN RIO Scanner or Mettler Jaquar
Paul The scanner is in slot 6 but I didn't see any Block Transfers or old school M0:6 / M1:6.
Can the SLC talk on RIO without these?
Sure...just a limited conversation...
I have not used the Mettler Toledo RIO interface. I got a quote once, for a Checkmate RIO interface and installation plus keeping the technician over night for startup the next day...It ended up cheaper for me to build my own scale controller and do away with their stuff on my case checkweigher.
So, I don't know how their communications work, and doubt that manuals are readily available, but I would expect that the basic stuff is all there in the discrete I/O.
OK I have only used RIO in SLC on robots, PV and Flex. I didn't know it could do simple reading without the BTs.
I learned something new today. Hopefully I don't have to go back and so a SLC install any more.
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
96
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
195
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
806
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,214
Hi, I have to test a control logic that required to change the input temperature as the process variable from thermocouple transmitter on the...
630
