Hsc s7-1200
JimZ1987
Jan 2011
Guayaquil
Please help me . I have to use a HSC for an encoder, for have as result frequency, and this I have to convert into an analog output as 0-10 V. How I can do this??
Hello, I use S7_1200. I Will measure frequency 5-100Hz. Any disadvantages or problems to consider if I use a Hardware HSC set to frequency and 1s?
1,807
Hello all, I have a strange problem with a high speed counter with a s7-1200. I have set up the hack input - it is a 2 channel a/b type which...
2,330
Hi I am designing a small system at work which will deposit liquid through a valve at a specific position. I have purchased a s7-1200 and will be...
1,911
I am working with a 1214 siemens plc and I have connected the pulse output of a flowmeter into the digital input of the cpu with the HSC enabled...
4,146
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is...
1,157
