Hsce2
gpcrisp
Sep 2003
Indiana
Ok folks my brain has officialy turned to mush. Years ago I programmed a system using the HSCE2 running two encoders in Quadrature X4 and a HSTP1 neither of which were very user friendly but we managed. Now another customer want to use the HSCE2 in class 4 mode 3 for 4 single ended counter inputs operating in ring with soft presets which upon hearing this gave me some bad flashbacks. After a day and a half of hacking at my old code and using the AB examples reading that poor excuse of a manual and talking to myself, I think my co workers are conspiring to have me commited. I don't like to ask for help but if somebody has some code that works in this manner and is willing to share it I would greatly appreciate it as would my co workers.
Thank You
Thank You for the reply Panic that is a very good thread but I have working code for 2 encoders. The problem begins when I try to enable all 4 counters. It hangs at counter config block. I can get two of the counters to work just not 4.
Ken Thank you for that info. We will be switching cards! That one is what the HSCE2 should have been. Thank you again for your help !!
Hi all I need your help, I have a 1746-HSCE2 card configured, the pulses read perfectly, but I have a problem as I use the pulse counters in...
2,184
Hi everyone. It's been a long time since I have asked for your help but I have been given a heap of plcs cards that have been changed out that...
1,216
I recently had to set up this module and would like to share what I learned, as this was a difficult process for me. The HSCE2 high speed...
2,119
I'm setting up the HSCE2 and just about have most everything coded and ready for testing. As anyone familiar with this card may know, the manual...
1,376
We have a fault with the existing HSCE card. I need to replace it with a new HSCE2 card. The processor is SLC5/03 Could some one please help me...
1,450
