HSP for 6es7 215-1al40-0xb0
Yes this looks like a good time to contact siemens support. I only have access to TIA15.1 right now and I couldn't find it the hardware list.
There's been quite a few discussions on other forums that do not appear to have a conclusion.
Try uploading from the CPU first, and see if it pulls the hardware configuration out.
If it is a new CPU without a program, then try downloading using 6ES7215-1AG40-0XB0 with your CPU and see what happens... you might just be limited to 125KB work memory. Only download if there is no existing program!!
Hi Sigmadelta, thanks for reply, but this PLC is programmed.
I tried using 6ES7215-1AG40-0XB0 and upload, but it disconnects.
Any help welcome.
Thanks for the tip, tried that, with the correct software 4.2.1, after updating the accessible devices it says unsupported. No luck sadly.
Good idea, tried it, no luck, same effect, 4.1 4.0 3.0 2.2 all the same, not supported.
The button detect remains gray.
I guess it only works with the HSP for 6ES7 215-1AL40-0XB0....
Siemens did not come through, no luck there,
They will not give the hsp.
If there is even a HSP for 6ES7 215-1AL40-0XB0 :cry:
That CPU was developed specifically for a German company (a huge one) and the only way to get the HSP (there is one) is to contact them or the supplier (contractor) of the CPU.
Hello Siemens experts. I am trying to register a GSDML file for an Endress & Hauser's Profinet IO over APL (Profile 4.0) compliant device. TIA...
212
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,866
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hi, I am using CM_CAN in my project in Transparent mode. The CAN modules needs transmit 240 message definitions each of 8 bytes, 168 message...
70
Hello: Just posted a similar inquiry with regards to Rockwell HART master. Trying to figure out whether the Siemens offering is better. I need to...
4,773
