Husky - FANUC Robot
luisoares
Nov 2012
Vale de Cambra
Good morning,
I am currently in Nigeria and I came across a problem with a Robot fanuc that is installed in a Huky injection machine.
The teach Pendant ( a05B-2301-c305) has all the LEDs On and only has the messages:
VRAM CLEAR CGRAM - COMPLETE
INTERNAL RAM TESTING - OK
EXTERNAL RAM TESTING – OK
Teach Pendant Ready.
But then it doesn't respond to any keys, any idea of the problem?
Good morning,
what do you mean doesn't respond to any keys? If you hold the deadman switch do you see the status bar at the top change indicating you are in the right position? can you move between screens and select a specific axis to move or a type of move?
When i cold the deadman switch, no status bar appears.
I can't move between screens.
this only appears
Usually deadman switch has 3 positions:
1.not pressed
2. pressed with small force
3. pressed with to much force
You need to press it with small force. Often with both hands.
It looks like it lost its program. The firmware booted, but without a program to run it's just sitting there.
If the program is read from the robot controller it could be a cable or connection problem where it is getting the 24 or 5V but not the communication.
1.not pressed
Fanuc is one hand, either side.
Must be an older robot, GE and Fanuc have been divorced for a while now.
Got to be close to 25 years old. The Power Motion branding was a thing in the late 1990s. I didn't realize it included robots though. But there was a high level deal between GE Fanuc and Husky. Husky got to buy their hardware direct from the factory without going through distributors and there were some custom modules.
The only Husky I can google looks like a XYZ stage and references to CNC. I imagine when using Fanuc drives, that teach pendant could be a method of editing a program in a CNC style controller.
I need to find out what is needed to talk to a Siemens 934. There are 4 in an injection molding facility and we need to know what it might take to...
1,527
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
62
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
142
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
133
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
123
