Hello, I have a system which consists of a AB 1769-L35E which has 4 hydraulic cylinders controlled by Rexroth servo valves (Each valve have the electronics built in and are controlled with +10V DC to -10V DC command from the PLC). Each cylinder has an encoder which provides feedback to the PLC. There are also pressure transducers on the system.
I have control over each cylinder manually and now need to program them to go to a given position or pressure.
What I need to do is move the cylinders to a given position or pressure. The speed will be determined by each Job.
What would be the best command to use for this purpose. Any help would be appreciated as I have never done any programming like this.
