The inputs are all 24volt dc off the base of he Plc. The outputs are 115v relays - not sure of the amperage.
Do these outputs power the existing solenoid valves directly or is there something in between?
Is there a 24 volt power supply?
I do have directsoft 5, andhave recently started playing with it some. Have the cable for it, and I've pulled the current program out.
This implies that you do not have the programing with the original author's comments and descriptions. If you do not have the original we will need a I/O list. The I/O list is a list of inputs (names) and their relationship with each input. The same goes for the outputs.
An example would be:
X0 Cycle push button
X1 start hydraulics push button
X2 stop hydraulics push button
X3 home position limitswitch
Y0 Follower shoe retract
Y1 Follower shoe extend
Y2 5in bend cyl w/large shaft extend
Y3 5in bend cyl w/large shaft retract
You may have to do this by manually by tracing the wires. There is also a way to use Direct Soft to help. Use the programing you previously uploaded from the PLC. Click on "PLC" at the top of the window, a dropdown list will appear, click on connect. Click on "Debug" at the top of the window, a dropdown list will appear, click on "all status on". Click on the "data view" icon, if you cannot find the "data view" icon, check under "view", "data view". At this point you should be online and a data view window should be open. One of the columns in the data view will be labeled "status" we are now interested in the other column. Place the cursor in this column and click on the first row, type in X0, hit enter, arrow up, then hit cntrl-enter this will populate the data view with X0, X1, X2 ect. for each cntrl-enter do this for the number of inputs on the PLC. Now when you push a button or move a limit switch you can see the status of the input change. So you should be able to see which button changes which input. After the inputs are done see if you can do the outputs.
If you are up to it you can enter the names of the inputs and outputs to their respective addresses. I think you can put the cursor in the row and click, then hit cntrl-d to bring up the descriptions editor. At this point you can name the address hit enter then cntrl-l to get you back to the data view. After you have done this you save your work find the files on your hard drive there should be between 5 to 10 with the same name but different file types .LDA, .LDO ect zip them up and post, we can then help with the rest of the descriptions.
I'm not actually resetting the redlion counter. Zero on the bend arm is zero, an it repeats day in, day out. I counts up to the setpoint, then back down to zero as the arm swing back. I hav gone months without resetting the zero.
I have attached a portion of the Gemini pdf. What I'm wanting to know is what is connected to the input I circled.
