Hydraulic press (Distance Measurement?)
osmanmon said:
the "sensor" will not determine the precision stop but "control system" will determine the precision stop.
Actually both are required. The weakest link principle applies.
http://deltamotion.com
This is the type of controller you need to use in lieu of a PLC in high-precision applications.
Yes, the end customer is too cheap to do it right so there was no point in suggesting our controller be used
The OP was right not to bid on this project.
We are challenged all the time by those that think they can do the job in a PLC cheaper. It never turns out that way and if they are too proud to say they were wrong they live with inferior performance. OK, so the difference in performance isn't that great but over time it adds up to real money.
"control system" i will refer to every thing involving sensor,actuator,bit that contribute precision result,
if OP only focus on 'sensor' and forget other things that will invite problem,
the customer want to go cheap product without care the consequence.
That's pretty typical of a customer. They want the capabilities of a fully-loaded military grade Humvee but think they'll get it for the price of a 1996 Suzuki Swift.
It's a real shame. I've used the Delta controllers and they really do work very well and are easy to set up. Sure, the hardware cost might be higher, but having me at your facility for three extra days trying to tweak a Micrologix program to do something it's not capable of doing costs even more. Unfortunately, too many customers only look at hardware cost and not labor.
There is a very old manually operating hydraulic forming press in our production. At the moment it's out of operation due to some issues with the...
17
6,118
Delta Computer Systems is putting on a press control webinar on 14th Apr at 8:30 PDT. The webinar will cover synchronizing multiple cylinders in...
24
6,973
I am quoting a retrofit for a small air over oil press. This small 5 ton press is now being used as a hand in die operation. The press controls...
18
6,160
Hello, I have an in-line (compression-20k)load cell installed on a vertical hydraulic press. The cylinders stroke is checked at home or fully...
5,335
Is anyone familiar with the "Link Electric" press controls? We are installing this system and it looks like old technology. I question whether...
2,131
