I am new here but with a big question
thermocouples are working good
What does "thermocouples working good" really mean?
That the junction weld has continuity?
That a supposedly "ungrounded junction" is not grounded to the sheath?
That the Constantan wire didn't mistakenly get coupled to alumel wire, making a b*a*s*t*a*r*d type T/C?
Or, are they looking for system to "certify" and calibrate up to 12 T/Cs in an oven/furnace at one time?
Or something else altogether?
In my mind, you're looking for solution to a grossly undefined scope.
If the task is truly certification, then the word 'cheap' isn't in the vocabulary of certification/calibration. The T/C manufacturers I know have specialty electronics just for ice point compensation, because cold junction error has to be minimized. And test and measurement grade electronics for calibration, not industrial grade electronics.
So, what exactly does your proposed test for a 'good thermocouple' do?
175
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
172
I received an email from a student with the following code attached. This is supposed to control a floodgate system, and supposed to be written...
23
905
I just converted an existing application from RSView32 to FactoryTalkView SE. In RSView32, the Datalog was made in a *.DBF file. There was...
120
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
215
