TWControls said:
IF you know the current IP Address of your controller so you know what to set your computers IP Address at, have all your firewalls and port blockers turned off...
Not really. Just need to know the MAC address, well not even that much.
-Plug CP/CPU into the network.
-Plug PG/PC into network.
-Set PG/PC interface to ISO Ind. Ethernet.
-PLC > Edit Ethernet Node
-Either fill in the MAC address if you know it, or use the browse function to search for every Siemens MAC Address. If you used a solid naming convention for all other CP/CPU's, then the one without a name is the one you want. Or look for the one with the generic 192.168....IP.
-Select it, then hit ok.
-Enter IP settings.
-Click on Assign IP configuration.
Within 2 mins it's up and running. Without me actually having to touch the CP/CPU.
If you are sitting next to the PLC, just use standard Cat 5 ethernet cable, PC and PLC both have port sensing so no crosscable needed, connect PC with PLC, PG/PC interface on ISO Ind Eth, search for aaccesible nodes, and download blocks. Make sure you download the SBD also.
Dunno about FW or ports, never had any troubles.
