I need experts help...
I spoke to siemens rep in my area, and he told me I am not being able to connect cause, I have downloaded microcomputing trail from the internet, therefore I have to purshase the software to be able to send real data to plc....
is this correct, is it because I downloaded the software from siemens web site I am not being able to communicate with my plc ?? and I have to buy it ??
you opinion is really important.
thanks.Farid
Hi Farid,
I had this error before when I use MicroComputing.
To correct this, you must follow the given instruction by siemens in the FAQ from the link I gave before.
It's a problem of size of your COM port buffer.
You need to set the lowest value in the receiving and sending buffer of your communication interface (COM1 for example)
I download as well from the website, I can use it during 5 minutes in demo mode before it ask for the licence number, so we buy a single licence.
Nicolas
French Student and PLC Beginner
hi Nicolas,
thanks for the reply,
I have followed the instructions given by the siemens web site, even though I am not using windows 95/ 98/ME , (I am using XP) I set the com buffer to the minimum ( the lowest) and still receiving that error
I can communicate with the plc when i am using microwin, but not microcomputing.
I am connecting my laptop to my plc via ppi cable, I drag SIMATIC data control( default name S7data1) and I also use some other controls like textbox, but I am not being able to browse the controler when I attenpt to define the data type to be read from the plc i.e vd10 ,mb5,etc
I am reading the manual every day and still not able to make it work ...i feel stupid :(
please help guys
Hi Farid,
I don't know if it's normal but It's disable on mine as well.
I did not try to find why because I assign directly the variable and not by the name of the variable I gave (I check with the symboltable from microwin)
Sorry, I can't help you of this problem
For the problem of connection, It was exactly the same message I had. I'm using win98 and I just change the size of buffers of my communication port and that's working after
Nicolas
ok thank you Nicolas you helped enough ...
I took my laptop and plc to siemens rep and he couldnt locate the problem, :D therefore I will purshase the software and if it works i will tell every body so they can be aware of this
thanks to all 🍺
I am a complete newbie with Omron plc’s. I have the software and leads (bought for another project but never used) but last week I was dragged...
2,241
Hi Guys, Anyone know who I can contact in order to find a cost effective oxygen concentrator for my needs? I have attached a PDF of the...
3,052
Hey guys, I'm in need of some expert knowledge to assist in some RsLogix 5000 programming, FBD. I currently have PIDE Loop 1 and PIDE Loop 2...
4,159
We are still not yet fully decided on the brand of motors and drives that we want to go with and standardize to. We are now looking at Rexroth...
20
10,786
Hello Ron, Please post my project and explain forum people what i am trying to solve. so in that way people can use their experience and opinion...
5,528
