i need help about siemens wf300 interface card
obyone
Oct 2005
eskisehir
22
hello,
i have a big problem, about siemens s5 system. there is a wf300 interface card which controlled the sk2l-330 wöndler panel. when i push the button on the panel the panel page must be change accordingly which button that i pust, but there is no change. when i pust the button there are input signal at I/O card of s5 but wf300 don't response. there is a led on the wf300 but there is not active. i take out the wf300 and i controlled the simple circuit element and i find a diode that brokendown. and than i change it and try again firstly my screen change but finally i had same problem.
is there anyone to help me on this matter?
thanks
Hi all, Got a call from a client that has several small water systems, asked me to take a look at one I've never programmed, just troubleshot a...
22
5,983
Hey guys, Run into another program. This stuff don't get easy when you start from only knowing the basic of programing to the mid advance stuff...
1,263
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,471
Hi people. I am from australia. Doing a plc course using siemens plc"s . Got given a task to design a pump cycle using two motors etc. The format...
2,778
Hello guys, I am new to the forum as well as to the Siemens PLC programming. So the problem that I am currently facing is to link S7-1200 1215C...
1,995
