I/O module's test signal terminals
unsaint32
Oct 2012
minneapolis
365
Some safety relay I/O modules have test signal generators. For example, Sick Safety Controller's I/O module has two safety signal generaros, X1 & X2. Many I/O modules have these test signals. What are these test signals? Can someone describe some applications that can explain why it is called "test" signal? Thanks.
These are outputs that switch on and off at certain frequency. When a safety device, like an E-Stop button contact, is connected between such a "test" terminal and a "safe" input, the safety controller expects to read the same pulse pattern back. This indicates the integrity of the safety circuit and adds a degree of reliability as compared to a circuit where e-stop is wired just to a DC power bus.
I see, it's sort of like the flashing LED for network Link status. Makes sense. Thanks Ladderlogic.
How can i test and address the module 6es54657la13 in a s5 program??
1,444
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
237
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
116
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
120
