IC695CPE305 write holding register using modbus
ryanneedshelp
Aug 2018
Pearland
Hi
Does anyone know if the IC695CPE305 plc supports writing to holding registers (%R in GE world) using the modbus tcp protocol.
I am reading registers from the plc just fine, but it looks like the controller is set to a read-only mode.
Regards
Ryan
It is capable, and yes the CPU does need to be configured to initiate R/W of TCP/IP.
IC695CPE305-ADAN Does anyone know what the ADAN means in the part/model number? Thanks, ctg
2,116
A while back I Converted a GE PCM module over to Modbus TCP. Due to the Discontinue of the IC693CMM321 I am redoing this project again. I am Using...
25
8,382
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
102
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
140
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
164
