Ideas for closing plastic bags
jagjag1
Jan 2012
Codesys
17
Hi I'm working on a bag in bag machine I have come to the last section on the machine witch is closing the bag. At the moment I'm using 2 resistance on the bottom and 2 on the top to melt and close the bag. The resistances are enclosed with an aluminum part and covered with Teflon to keep the bag from sticking to the aluminum.
The problem I'm facing is that the I don't get a constant temperature on the heating area and because of this my bag opens or melts on some parts. I have seen machines using a copper wire (5mm width) to a temperature and then closing the bag with it. Have anyone got any experience which way is better?
The bags a thin LDPE and at the moment I need 150 degrees c and a closing time of 400ms.
Thanks in advance
you can use a static relay to control the resistance, a thermocouple or RTD to get the actual Temp. and PWM output to control the relay
We have used a Ropex controller in the past with TOSS heating elements. Try to search for TOSS heating elements and/or Ropex resistron controller. These worked very well with excellent temperature control.
You need a very small straight line with uniform heat, Use a heat wire (for example out of a toaster)
put a teflon tape over it.
the other side a simple piece of tape, over rubber or alike.
control the temp by using a PWM set (for example a arduino,
when the thing is closed the power must be ON. full.
another way is to use a heated wheel.
In my kitchen drawer is a very simple bagsealer working on a battery.
...and make sure that the area being sealed is not subject to blasts of air from another part of the machine or nearby doors opening and closing.
Thanks for all your answers. This is for an industrial application so I need something rugged and already made.
I think I wasn't clear enough. I can control the resistances to an accuracy of +-1 degree C with resistances integrated with thermocouple J, but when I measure the surface of the aluminum then it differs quite a bit depending on where I'm aiming the temperature controller (from left to right see exmaple bellow)
R1 ------------------------- R2
170 185 185 170
This is why I'm searching for a more reliable and constant heatingsource for example a thin wire. I like the idea with a heat wire but I can't deliver a machine with parts from a toaster to my costumer, so if anyone have any idea where I can buy one for industrial use and the electrical components needed for heating it and controlling the temperature.
**170***185**185*****170
The lower temps that you see near the ends of the aluminum would indicate that there is more surface are to dissipate the heat near the ends than there is in the center. you may need to insulate the aluminum to prevent losing so much heat into the ambient air.
the toaster was just an example, it is the principle.
the wire is available in several sizes.
you will have to play with time, temperature and closing pressure.
it is tricky, and you will need a lot of experience, special if the foil is thin.
always have the machine moving, and only close when need sealing.
if yu want to close loose bag from a box, use 2 finers to keep the bag tight, not having rinkels.
keep the closing area by filling with a pipe.
I was just wondering if anyone had any experience with a VEGAPULS C 22 Radar sensor. One of my customers got a cold call from one of there reps...
2,800
Hello Collegues ! I am here today looking for help, i recently started a magister in controls and automation. I was thinking in doing an automated...
2,015
We have AOIs for projects, which handle material dosing (by hand or by pipes and pumps), obviously they have comparison between setpoint and...
50
14,271
Wizards, With all the extra downtime this year, I have started guiding the newer maint staff through a test cell build. It has been quite...
1,369
This is a little off the PLC topic but hopefully within the wheelhouse of people here! We have a client who has asked if on a future project they...
5,637
