Idec clip
T Gibbs
Jun 2012
Morristown, TN
406
Hi all,
I have an old IDEC FA-2J PLC that I am trying to get the program from. I have it uploaded to my PC and converted to ladder. I am trying to print it out and it always says "Printer not ready". Can someone tell me how to set it up to print? I can't find any place to select the printer I want to use. It is a network printer. It works fine through windows based programs, but this DOS based stuff is beyond my knowledge. 🔨
Zip and attach the files here in the thread. Someone should be able to convert them to a .pdf file. Then, you could print out the .pdf file. You might also Google a program called DOS2USB. It plus CutePDF Writer will allow you to print some DOS programs directly to .pdf files.
Here are some links:
http://www.dos2usb.com/
http://www.cutepdf.com/
It's probably trying to print to the parallel port (LPT1). A quick Google search for 'redirect lpt1 to network printer' says that NET USE LPT1: \\computer name\share name of printer should point it to the right place.
Can you 'print to file' instead? That would produce a text file that you can print from Windows.
-Eric
I have a machine with an IDEC FA1 Jr PLC. I'm looking at putting in a more modern processor. I was looking at the ladder and I understand the...
1,499
Good Afternoon, So we are doing some upgrades to a older water plant which is currently using a old Idec FA3S Processor which is programmed via...
4,470
Hi, I am having trouble viewing IDEC FA-1 ladder logic files. How can I view an IDEC FA-1 ladder file offline? I keep on getting an error...
2,217
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
93
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
576
