IDEC FC2A-C16A1 & WindLDR software
technolog
May 2015
Ohio
320
Hi, we have an IDEC Micro3 FC2A-C16A1 PLC from which we need to get an upload. Is anyone able to confirm that WindLDR is the correct software and if so are there specific versions I need for the FC2A-C16A1?
I've done a bit of searching, hoping that the software might be available as a free download but had no luck so far. WindLDR (part# FC9Y-LP2CDW) does appear to be for sale at a few places - Allied & OnlineComponents for example. It doesn't say what version it is but says on the datasheet that it's for all IDEC PLCs. Is anyone able to confirm that it will work?
https://www.onlinecomponents.com/idec/fc9ylp2cdw-11549355.html
It looks like Geniusintraining has a cable for sale for $150.
I believe the FC3A uses OpenNet which is an option in the WinLDR I'm currently in v8.8.0 part of Automation Organizer V2. I think I'm a bit behind as I haven't had WinLDR open in a year but it should be in the latest version too.
Hope this helps at least a little.
Ken
Thanks for that, both. I'm waiting on a decision from the powers that be to see if they want to spend the $300.
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
86
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
568
Has anyone interfaced a PLC with a Control Techniques drive Nidec 750 using Modbus TCP? I am attempting to do so using an Automation Direct...
900
I'm involved in upgrading an IDEC FC5A-D12S1E PLC to a FC6A-D32P3CEE. I've attached the original layout of the system. Since then, another HG3G...
443
Hallo all, We are servicing machine automation using PLC Idec FA 2J. I'm trying looking for the PLC user manual, but till now didn't get at all...
789
