Throwing a hail marry here. We have been using IDEC RTE timers for decades at our plant. Specifically RTE-P1AF20 and RTE-B2AF20. We recently built a new MCC/ transformers as part of expansion. Inside MCC we are using IDECs for some controls and noticed intermittent failure of RTE relays shortly after commissioning. Upon further investigation we found the same failed relays work perfectly outside of the new MCC. After checking all voltages [120vac] and switches everything seemed to be in order. In a last ditch effort we ran a separate 120vac circuit from a different, close by MCC and everything at that point worked perfectly. Currently, one month later, testing of relays in new MCC they appear to be working properly. Currently have our electrical contractor doing some power quality studies. Has anyone seen this situation before?
