Iduction motors, Dual speed, Dual voltage, Y/Delta
kalabdel
Feb 2015
Ontario
1,108
Greeting to all,
I seem to never get a handle on motors and their operation and I was reading this WEG pdf which puzzled me.
So we have dual voltage motors that have their winding wired in series or parallel.
Y start and Delta run, motor starting method for certain applications.
Dual speed (Dahlander) Motors, and that's where things went sideways for me. The wiring illustrations (see image "Page 30") dual speed motors wired for three different applications, Constant Torque, Constant Horsepower and Variable Torque.
Assume we have the same voltage for all (that's my assumption).
  • Constant Torque low speed:
    • Pole pairs are wired in series and the three phases are wired in delta configuration.
    • Constant Torque high speed:
    • Pole pairs are wire in parallel and the phases are wired in Y configuration.
    • Question #1: Will the windings in this configuration "see" more voltage? (see middle drawing in image "Page 19")
    • Question #2: Doesn't fewer poles (wired in parallel) produce less torques?
  • Constant Power:
    • The wiring diagrams are place opposite to the one above it.
    • The Wye configuration with parallel pole pairs should be the high speed and the Delta should be the slow speed.
    • Questions #1: What I missing concerning the speed?
    • Question #2: How did it become constant power?
  • Variable torque:
    • I think I understand this one, they Wye configuration with winding wired in series will drop the current and the torque goes down with it and with Delta configuration we will have less poles(paralleled) and more current meaning more torque, am I on the right track?
Last question: What is the symbol "SH1" in the image "symbol"? It is noted as Control Button and there are two contacts, one is NO and the other is NC. If it is a button and they're the contacts are linked then when the button is pushed nothing would happen; so there must be something I'm missing.
"I seem to never get a handle on motors and their operation"
And you choose to start with a Dahlander circuit?
I've only come acrross this circuit once, on the inlet screw pumps at a sewage works.
SH1 is a clumsy representation of the Start & Stop buttons and also the Running Lamp.
It's a bad schematic - SH1 is shown 3 times:
SH1 n/c , terminals 21-22 = STOP Button
SH1 n/o, terminals 13-14 = START Button
SH1 Lamp, terminals X1-X2 = RUNNING Lamp
Thanks gentlemen.
@soultrader, constant torque and constant power was mentioned in passing in a conversation I had with a motor repair technician and I got curious as to how they worked. That led me to that WEG pdf and Dahlander.
The switch didn't make sense to me, the way the two contacts are linked, and thought there maybe some specialized buttons for this application. Thanks for clearing this up.
@widelto, I had a quick browse and it looks good. I will dig deeper into it tonight.
Cheers
Kal
Dear colleagues, hope you can help on that matter. We have a project where we need to control 3 servomotors to move a auger feeder system...
38
1,176
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
227
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
831
I'm working on a design phase for a costumer and they've requested PM motors for all conveyor belts throughout the system. We have a gapping...
529
Hi guys, I have a problem with setting up the parameters for PowerFlex 525. So we have 4x motor connected in parallel to 1 PowerFlex, each motor...
1,092
