Iec 61131-3 ?? What is it?
Timeismoney08
Jul 2012
United States
312
Hello and happy new year!
I would like to further understand who needs to design by this standard and is it a requirement for everyone or only those who list it as there design standards to a customer?
Secondly, is Rockwell considered 61131-3 compliant? Also, is there any manufactures that are not compliant?
Thank you for the help!
1)Most PLC manufacturers are "compliant" in that they have, somewhere, a document that says which PLC languages support which features in the IEC spec. You comply with the spec basically by listing where you deviate. As the Pirates say, "it's more a guideline than a rule".
There are very few systems that 100% conform to IEC. It is generally not feasible to directly copy code from one platform to another, although you are more likely to be successful with structured text.
2) A big part of the reason for this is that many manufacturers have implemented new functions not called for in the IEC spec. Some also implement features in different ways.
3) Big picture, the IEC standard plays almost no role in the day to day work of a controls engineer or PLC programmer.
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,128
I was poking through the Stackoverflow PLC Tag when I saw this answer to a question about converting a Real to a DWord and back again. What...
2,909
I am looking for some expert advice. I have always made function blocks both with inputs and outputs and without inputs or outputs. I make the...
21
6,794
So Ladder is easy to read graphically, most everything can be coded in ladder, and it represents wiring diagrams the closest. SCL and ST are good...
1,739
Hello, I have been looking at the Yaskawa website for documentation on G-code sample programs. I was unsuccessful at finding any IEX 61131-3...
2,783
