IEC symbols good reference
Photo eye
Looks like a photo eye, see the LED and arrow symbol inside. It also has complementary output.
Wavey line instead of arrows is a prox
ivo how did you come up with the "B = sensor so I can learn something
I have never seen any reference to that before
I know the br bl are power in, the diode with arrow pointing away is a standard for opto diode or LED the output looks like it is complimentary pare output but I can't make out the color of the output wires. that color can be an indication of the function or not depending on the manufacture
I always thought the label outside of the symbol is just an identifier on the print
the complete circuit would be helpful to see how it's used
Both IEC 60617 and IEEE 315 have item designation codes listed in them. B is often used for transducer.
The symbol shown appears to be a transducer of some type. In it's general form it takes whatever is shown in one corner and converts it to what is in the other corner. So, looking at this one it changes the Pi-symbol into a photo-isolated digital signal. I'm not sure what 'pi' represents in this case. It could possibly be run-out. I'm just guessing.
We have a customer who wants us to produce drawings as per UL/CSA norms. Should I use JIC or IEC symbols?
1,416
Where is the symbol list entered for i/o in the IEC developer? for example i want to call X1 input 1 with a comment? in gx developer it is in the...
2,601
I am trying to deal with fragmented data, and have been getting stuck. So far I am able to command the Fuchs VE Software version correctly and I...
168
Hi all, I am getting back to using IEC for schematics and was wondering about the 81346-2:2019 codes. What does everyone use for a diffuse...
570
I just took a skim through 81346-2:2019 and was wondering which codes you all used for Safety devices like Safety Controllers, EStops, and guard...
568
