iFix 3.5 and OPC server
asterof
May 2007
Califonia
554
Trying to resurrect an old iFix 3.5 system
There is no database all the tags are dynamic tags
with indirect opc connections
So I need a little refresher here
the tags on the displays look like this
rsopc'[pxrw].SP301_VFD'
Now I am going to assume
rsopc means rslinx needs installed
pxpw is a topic
the topic in rslinx would point to a PLC
and the SP301_VFD would be the tag
Yes ? No ??
Additional Info
pxpw is a topic
Yes ? No ??
I was thinking of changing these to a Database
anyone know of a program that can search and replace
or search and export from the display
Hello, I created a browser data base file (.bdb) using the Opto22 Browser Configurator 10.4 program. For communication between Opto22 and IFIX...
619
Can anyone tell me the proper I/O address format to use for doing this? I've done this a million times with Modicon, but that driver doesn't...
5,488
Define a technical solution to generate an iFix database that will allow customer to capture A&E data A customer want to use an OPC based program...
2,035
'IGS.B88_QC.B88_QC.Global.U_7087X001PDS101.STS.CMF' so in this display I have links like this, now I have seen direct opc to plc before but I...
1,990
Hi all Can any one tell me on how to communicate bristol control wave plc to ifix using opc drivers in ifix...pls...its in critical stage...
2,281
