iFix IGS Indrect OPC connection
asterof
May 2007
Califonia
554
'IGS.B88_QC.B88_QC.Global.U_7087X001PDS101.STS.CMF'
so in this display I have links like this, now I have seen direct opc to plc before
but I remember I had to set the default OPC path in windows
So you think that what was done here
The IGS is talking to the PLC
and there are no database tags
These do exist Global.U_7087X001PDS101.STS.CMF
but the
Channel 1 = Network
Device1 = B88
then there is a Global
so
Network
B88
Global.
PRM.Clean
Any idea what this breaks down to
Uh, bit of a WAG here.
IGS.(The driver)
B88_QC.(The instance for the first, The PLC for the second)
Global.(This is telling you it is a global tag, not local to a task)
U_7087X001PDS101.STS.CMF(Some fairly horrible tag name, i'm sure it means something to the original programmer)
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,924
I am talking to a Logix 5500 series PLC with ABR driver currently. IFIX Database shows addressing setup like this -...
1,786
Hello all, I found a few related threads but none seemed to resolve my issue, hence the new post. I am working on migrating an existing iFix...
2,953
New to iFix and to the IGS driver. Environment: iFix V5.1 MODICON M340 Unity-pro V11. Memory set to Mixed Topological and State RAM. MODBUS TCP/IP...
6,547
It's been a while since I did a big jump like this, and I built a new PC for the client with 5.8 and the latest version of IGS. They were using...
3,021
