Migrating IFIX 3.5 to 5.8 (TOP server to IGS)
phuz
Jun 2008
Mohnton, PA
1,044
It's been a while since I did a big jump like this, and I built a new PC for the client with 5.8 and the latest version of IGS. They were using the TOP server before, and I don't know what the config file is that it used. Since they are basically the same format, I was hoping to just load it into the IGS driver, but I can't even find what I'm looking for.
Hopefully you aren't going to tell me I have to go back to the site and export the TOP server to a csv and import that into IGS. :)
It would be easiest for you to do that thing :D
I haven't used IGS in a while, but I believe the configs aren't 1:1.
I do seem to remember the config being text based, Seem to remember being able to convert from it when I was migrating stuff over to a historian.
So the extension is the same as the IGS.
And there is no OPF in my project folders. I wonder if its stored somewhere else on their PC.
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
We are upgrading our FTV ME v8.1 program to SE v12. Is there any way to migrate the alarm tags (about 600ish) from ME to SE. The import / export...
842
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,750
I just want to get others thoughts on what is the biggest obstacle one faces in migrating to a newer system? For me with the few systems I have...
17
4,125
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,394
