iFix and IGS Comms
kmayreis
Sep 2018
OH
Hello all,
I found a few related threads but none seemed to resolve my issue, hence the new post.
I am working on migrating an existing iFix database (v4.0) to a new version of iFix (5.9) and communicating via IGS v7.63 instead of ABR and RSLinx.
My existing addressing on a DI block looks like this for the ABR setup:
FILT1:N100:2:5
In IGS, I think it should look like this:
WWTP.FILT1.Global.N100_x.N100_02.[5]
IGS appears to accept that, because I do not get an error in the IGS Event Log. When formatting different than that, I did get errors (i.e. "..N100_02.[05]" results in a "Unable to read tag." error.
Despite no error from IGS, my iFix DB shows ????? for that tag. What am I doing wrong?
Thanks!
IGS is rebranded Kepware OPC server. You can find the Allen Bradley driver document some where on your PC.
or you can get from this link:
https://www.kepware.com/getattachme...e29a2eaecac/allen-bradley-ethernet-manual.pdf
Also, iFix DB is picky sometime about it's format. You may have to specifically append @BOOL or @FLOAT to the end, for example.
I haven't dealt with SLC type tag for a while... have you tried just WWTP.FILT1.N100:2.5 or 2/5?
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,924
I am talking to a Logix 5500 series PLC with ABR driver currently. IFIX Database shows addressing setup like this -...
1,786
New to iFix and to the IGS driver. Environment: iFix V5.1 MODICON M340 Unity-pro V11. Memory set to Mixed Topological and State RAM. MODBUS TCP/IP...
6,547
It's been a while since I did a big jump like this, and I built a new PC for the client with 5.8 and the latest version of IGS. They were using...
3,021
'IGS.B88_QC.B88_QC.Global.U_7087X001PDS101.STS.CMF' so in this display I have links like this, now I have seen direct opc to plc before but I...
1,989
